Electrical Maintenance Engineer – Shift Brentwood, Essex £45,000 – £50,000 + Bonus + Excellent Benefits Permanent...? If you’re an Electrical Maintenance Engineer, Maintenance Electrician or Industrial Electrician looking for a secure plant-based...
Electrical Maintenance Engineer – Shift Southend-on-Sea, Essex £45,000 – £50,000 + Bonus + Excellent Benefits...? If you’re an Electrical Maintenance Engineer, Maintenance Electrician or Industrial Electrician looking for a secure plant-based...
Electrical Maintenance Engineer – Shift Rainham, Essex £45,000 – £50,000 + Bonus + Excellent Benefits Permanent...? If you’re an Electrical Maintenance Engineer, Maintenance Electrician or Industrial Electrician looking for a secure plant-based...
Electrical Maintenance Engineer – Shift Basildon, Essex £45,000 – £50,000 + Bonus + Excellent Benefits Permanent...? If you’re an Electrical Maintenance Engineer, Maintenance Electrician or Industrial Electrician looking for a secure plant-based...
, Fitter electrical fitter, maintenance engineer, shift engineer or maintenance engineer may be suitable for this position...Job Title: Electrical Maintenance Engineer - Shifts Location: Derby area Pay Range: £50-53.5k plus overtime 8 Hour...
Equans currently has an exciting opportunity for an Electrical Shift Building Maintenance Engineer to join our team... for the safe operation, planned and reactive maintenance of mechanical/electrical systems, associated plant/equipment...
for all maintenance and stock activities Requirements: Essential skills for this role: NVQ Level 3 Electrical/Electronic Engineering..., reactive and corrective maintenance work on our plant equipment. Our goal as a team is to continuously improve machine...
for all maintenance and stock activities Requirements Essential skills for this role: NVQ Level 3 Electrical/Electronic Engineering... and corrective maintenance work on our plant equipment. Our goal as a team is to continuously improve machine reliability...
We are looking for a skilled and motivated Maintenance Technician to join a well-established maintenance team. You will play a key role in keeping... manufacturing operations running smoothly by carrying out planned preventative maintenance, reactive repairs, and continuous...
The Shift engineer performs work including activities which are complex and/or non-routine in electrical services..., isolation, modifying, inspecting, improving, installing, maintaining and repairing of all electrical services, plant...
